HP iPAQ Data Messenger - Specifications
System specifications
Features
Windows Mobile 6.1 Standard Edition.
Bluetooth
v2.0 + EDR*
* A standard GSM/GPRS/EDGE/UMTS/HSPA infrastructure, Wi-Fi network access, other Bluetooth-enabled devices, separately purchased equipment, and a service contract with a wireless service provider may be required for applicable wireless communication. Wireless Internet access requires separately purchased Internet service contract.
Check with service provider for availability and coverage in your area. Not all web content available. Normal GSM Data Calls (CSD) are not basic GSM data services. These services may not be available via all service providers, and may require separate subscription. Establishment and continuation of a wireless connection depends on network availability, provider support and signal strength. Coverage is subject to transmission limitations and terrain, system, capacity and other limitations. Not all features and service options are available in all areas.
Memory
128M SDRAM/256MB Flash ROM.
Charge/sync connector
Micro-USB.
Headset
2.5 mm stereo headset jack.
Dimensions (HxWxD)
4.5 x 2.24 x 0.69 inches/114.5 x 57 x 17.4 mm
  • 164 grams (with battery)
  • 137 grams (without battery)
Temperature
  • Operating: 14 degree to 131 degree F (–10 to 55 degree C).
  • Storage: –4 degree to 140 degree F (–20 to 60 degree C).
Box contains
  • HP iPAQ Data Messenger.
  • 1140mAh rechargeable battery.
  • micro-USB sync cable.
  • AC charger.
  • 2.5 mm wired stereo headset.
  • HP iPAQ Getting Started CD.
  • Documentation kit.
Communications
Features
Wireless Wide-Area Network (WWAN)*
Technology :
  • UMTS – Universal Mobile Telecommunication System.
  • HSDPA – High-Speed Downlink Packet Access.
  • HSUPA – High-Speed Uplink Packet Access.
  • EDGE – Enhanced Data for Global Evolution.
  • GSM – Global System for Mobile Communications.
  • GPRS – General Packet Radio Services.
* A standard GSM/GPRS/EDGE/UMTS/HSPA infrastructure, Wi-Fi network access, other Bluetooth-enabled devices, separately purchased equipment, and a service contract with a wireless service provider may be required for applicable wireless communication. Wireless Internet access requires separately purchased Internet service contract. Check with service provider for availability and coverage in your area. Not all web content available. Normal GSM Data Calls (CSD) are not basic GSM data services. These services may not be available via all service providers, and may require separate subscription. Establishment and continuation of a wireless connection depends on network availability, provider support and signal strength. Coverage is subject to transmission limitations and terrain, system, capacity and other limitations. Not all features and service options are available in all areas.
Telephone service requires separately purchased contract with a telephone service provider with coverage in your service area. Additional fees may apply for some features, check with service provider.
Audio
Features
Audio
Input:
  • Voice recording.
  • Built-in mono-speaker.
  • Microphone on bottom of unit.
Output :
  • Speaker designed for voice playback.
  • Built-in speaker on the back of the device.
  • Speaker on front of unit for handset earpiece audio.
  • Audio jack for stereo headset.
