Loading Paper and Printing With the HP Officejet Pro 8500 (A909) All-in-One Printer Series
This document provides instructions for loading and printing on 216 x 279 mm (8.5 x 11 inch) plain paper.
Loading and printing from the main tray
Follow these steps to load and print on 216 x 279 mm (8.5 x 11 inch) plain paper.
Step one: Load plain paper
  1. Lift the output tray.
    Figure : Lift the output tray
    Illustration of output tray lifted
  2. Load the paper print side down in the center of the tray. Make sure that the stack of paper aligns with and is no higher than the line on the width guide.
    Do not add paper while the product is printing.
  3. Slide the paper width guides in the tray so they rest snugly against the paper, and then lower the output tray.
    Figure : Adjust the paper guides
    Illustration of paper guides
  4. Pull out the extension on the output tray.
    Figure : Extend the output tray
    Illustration of an extended output tray
Step two: Print on plain paper
  1. Open the document that you want to print.
  2. On the File menu, click Print.
    Specific options might vary depending on the application that you are using.
  3. In the Print dialog box, click Properties or Preferences.
  4. Select 8.5 x 11 from the Paper Size menu.
  5. Select Plain paper from the Paper Type menu.
  6. Change any other print settings that you want, and then click OK to confirm the settings.
  7. Click Print to send the print job.
