    Fix HP Printer issue on macOS
HP Pavilion w1858 Monitor - Product Specifications
The HP Pavilion w1858 is a 18.5-inch wide-screen monitor with liquid crystal display (LCD) and thin-film transistor (TFT) screen.
Figure : Photo of the HP Pavilion w1858 LCD wide-screen monitor
FN773AA
Features
The HP Pavilion w1858 LCD wide-screen monitor has the following features:
  • 1366 x 768 factory-set resolution
  • Video inputs supported:
    • DVI connector
    • VGA connector
  • Supports High-bandwidth Digital Content Protection (HDCP) to prevent transmission of non-encrypted high definition content
  • Plug and Play capability, if supported by your computer system
  • On-screen display (OSD) adjustments for ease of setup and screen optimization
Technical specifications
LCD feature
Specification
Display size
18.5-inch (46.99 cm) diagonal and viewable image
Display type
Thin-Film Transistor LCD active matrix
Input terminal
1 DVI connector
1 VGA connector
Other connectors
3.5 mm stereo mini jack input (for microphone)
Integrated speakers
2 watts per speaker
Scanning frequency
Horizontal scan range 24-83 KHz
Vertical scan range 50-76 Hz
Viewing angle
Horizontal viewing angle: 170 degrees
Vertical viewing angle: 160 degrees
Recommended resolution (H x V)
1366 x 768 @ 60 Hz
Contrast ratio
Up to 1000:1
Response time
5 ms (on-off)
Pixel pitch
0.30 mm
HDCP (High-bandwidth Digital Content Protection)
Support for HDCP enables the monitor to display HDTV resolution if connected by the DVI connector. A monitor without HDCP support, or connected by analog VGA, causes the displayed video to be downgraded in quality to a DVD-like resolution that is less than HDTV.
HDCP is also a content protection system. The goal of HDCP is to prevent transmission of non-encrypted high definition content.
Power source - AC/DC adapter
Input rating: 100 to 240V~
frequency: 50~60Hz
Power consumption: 40 watts maximum power consumption in operating mode, <2 W in sleep mode
Operating environment
Temperature: 41 degrees F to 95 degrees F (5 degrees C to 35 degrees C )
Humidity: 20% RH through 80% RH (non-condensing)
Storage environment
Temperature: -29 degrees F to 140 degrees F (-20 degrees C to 60 degrees C)
Humidity: 5% RH through 95% RH (non-condensing)
Dimensions
H x W x D (unpacked):
13.98 x 17.95 x 7.24 inches (35.5 x 45.6 x 18.4 cm)
Unpacked: 9.48 lbs (4.3 Kg)
EMI standard
FCC Class B
Mounting
Standard VESA 4-hole 100 mm x 100 mm
