    Fix Windows 10 Update Issues
HP Compaq 8710w Mobile Workstation - Removing and Replacing the Expansion Memory Board
This document is provided to assist in removing and replacing the Expansion Memory Board for the HP Compaq 8710w Mobile Workstation.
Minimum skill level
Tools required
  • Phillips P1 screwdrivers
  • Flat-bladed screwdriver
Parts required
The replacement part number will vary depending on the Expansion Memory Board that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
4096-MB (PC2-5300, 667-MHz, DDR2)
469650-001
Yes
2048-MB (PC2-5300, 667-MHz, DDR2)
450576-001
Yes
1024-MB (PC2-5300, 667-MHz, DDR2)
450575-001
Yes
512-MB (PC2-5300, 667-MHz, DDR2)
450577-001
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the Expansion Memory Board, click on the link below. Or use the product video listing on the HP Services Media Library, then select Expansion Memory Board from the menu on the upper left hand side of the screen.
Click here to view the Expansion Memory Board removal video (right-click on the link to open in a new window/tab).
  2. Loosen the three captive P1 Phillips-head screws that secure the expansion memory/wireless LAN Minicard cover to the bottom of the notebook.
  3. Use your finger or a flat-bladed tool to lift the edge of the expansion memory/wireless LAN Minicard cover and remove it.
  4. Push both arms outward simultaneously to release the expansion memory board to the spring tension position.
    When handling a memory board, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
  5. Grasp the expansion memory board by the edges and pull gently to remove it.
  6. Place the expansion memory board in a static dissipative bag.
Expansion Memory Board replacement
  1. Remove the expansion memory board from the static dissipative bag.
  2. Locate the alignment slot and align it to the empty board receptacle.
  3. Grasp the expansion memory board by the edges and push gently to replace it.
  4. Press the expansion memory board down to latch the arms.
  5. Toe the expansion memory/wireless LAN Minicard cover into the enclosure.
  6. Tighten the three captive P1 Phillips-head screws.
Parts return
