HP LaserJet P2030 Series Printer - Replace print cartridge
Supply replacement guidelines
Keep the following guidelines in mind when setting up the product.
  • Sufficient space is required above and in the front of the product for removing supplies.
  • The product should be located on a flat, sturdy surface.
Hewlett-Packard recommends the use of HP supplies in this product. Use of non-HP supplies can cause problems requiring service that is not covered by the HP warranty or service agreements.
Redistribute toner
When toner is low, faded or light areas appear on the printed page. You might be able to temporarily improve print quality by redistributing the toner.
  1. Push the button to open the print-cartridge door, and then remove the print cartridge.
    Figure : Print-cartridge removal
  2. To redistribute the toner, gently rock the print cartridge from front to back.
    Figure : Rocking motion
    If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric.
  3. Reinsert the print cartridge into the product, and then close the print-cartridge door.
    Figure : Print-cartridge insertion
If the print is still light, install a new print cartridge.
Change the print cartridge
When a print cartridge approaches the end of useful life, you are prompted to order a replacement. You can continue printing with the current cartridge until redistributing the toner no longer yields acceptable print quality.
  2. Remove the new print cartridge from the bag. Place the used print cartridge in the bag for recycling.
    Figure : Print-cartridge package
  3. Grasp both sides of the print cartridge and distribute the toner by gently rocking the print cartridge.
    Do not touch the shutter or the surface of the roller.
  4. Bend the tab on the left side of the cartridge until the tab breaks loose. Pull the tab until all the tape is removed from the cartridge. Place the tab and tape in the print-cartridge box to return for recycling.
    Figure : Print-cartridge shipping lock and tape
  5. Align the print cartridge with the tracks inside the product, insert the print cartridge until it is firmly seated, and then close the print-cartridge door.
  6. Installation is complete. Place the used print cartridge in the box in which the new cartridge arrived. See the enclosed recycling guide for recycling instructions.
For additional help, go to www.hp.com/support/ljp2030series.
