HP LaserJet P2030 Series Printer - Product basics
Product comparison
HP LaserJet P2030 Series models
HP LaserJet P2035 printer
CE461A
Figure : HP LaserJet P2035 model
HP LaserJet P2035n printer
CE462A
Figure : HP LaserJet P2035n model
  • Prints up to 30 pages per minute (ppm) on Letter-size paper and 30 ppm on A4-size paper
  • Contains 16 megabytes (MB) of random access memory (RAM).
  • HP print cartridge, rated for up to 1,000 pages
  • Tray 1 holds up to 50 sheets
  • Tray 2 holds up to 250 sheets
  • 125-sheet face-down output bin
  • Straight-through output path
  • Hi-speed USB 2.0 port
  • Parallel port
Has the same features as the HP LaserJet P2035 model, with the following differences:
  • On-board networking
  • No parallel port
Product features
Feature
Performance
  • 266 MHz processor
User interface
  • 2-button, 6 LED control panel
  • Windows® and Macintosh printer drivers
  • Embedded Web server to access support and order supplies (for network-connected models only)
Printer drivers
  • Host-based printer drivers for Windows and Macintosh, included on the product CD
  • HP UPD PCL 5 printer driver, available for download from the Web
  • XML Paper Specification (XPS) printer driver, available for download from the Web
Resolution
  • FastRes 1200—produces 1200-dots-per-inch (dpi) print quality for fast, high-quality printing of business text and graphics
  • 600 dpi—provides the fastest printing
Fonts
  • 45 internal scalable fonts
  • 80 device-matching screen fonts in TrueType format available with the software solution
Connectivity
  • Hi-Speed USB 2.0 connection
  • Parallel connection (HP LaserJet P2035 printer only)
  • RJ.45 network connection (HP LaserJet P2035n printer only)
Supplies
  • The supplies status page contains information about toner level, page count, and approximate pages remaining.
  • The product checks for an authentic HP print cartridge at installation.
  • Integration with HP Sure Supply Web site for easy replacement-cartridge reordering
Accessories
  • HP Jetdirect external print server
Supported operating systems
  • Microsoft® Windows® 2000, Windows® Server 2003, Windows® XP, and Windows Vista™
  • Macintosh OS X V10.3, V10.4, V10.5, and later
  • Unix®
  • Linux
Accessibility
  • The online user guide is compatible with text screen-readers.
  • The print cartridge can be installed and removed by using one hand.
  • All doors can be opened by using one hand.
  • Paper can be loaded in Tray 1 by using one hand.
Product walkaround
Front view
    Figure : Front view
  1. Tray 1 (pull to open)
  2. Top output bin
  3. Control panel
  4. Print-cartridge-door release button
  5. On/off switch
  6. Tray 2
  7. Print-cartridge door
Rear view
    Figure : Rear view
  1. Jam-release door (pull the green handle to open)
  2. Straight-through paper path (pull to open)
  3. Interface ports
  4. Power connection
  5. Slot for a cable-type security lock
Interface ports
    Figure :
  1. Hi-speed USB 2.0 port
  2. Parallel port
    Figure :
  2. RJ.45 network port
Model and serial-number label location
The label that contains the model and serial numbers is on the rear of the product.
Figure : Location of model and serial-number label
