HP Photosmart Consumer Station
Standard components
Digital input
Dimensions
19 inches x 16.3 inches x 21.4 inches (48x41x54cm)
90lb (41kg)
Power requirements
110–240 V auto ranging, 10 A
Additional order stations (optional)
Up to five additional consumer order stations can be added to one base configuration
HP Photosmart Order Management Station
Standard components
HP Photosmart Studio software suite
HP Photosmart order management station
HP Photosmart Studio finishing equipment
Dimensions
21.5 inches x 20.5 inches x 18 inches (55x52x46cm) rack case
43lb (20kg) rack case
Power requirements
110-240 V auto ranging, 10.8 A
HP Photosmart Creative Printer
Printing technology
HP dry electrophotographic
Paper size
Printer resolution
HP ImageREt 4800
Print speed
12 pages/minute (8.5 inches x 11 inches, 22x28cm, duplexed)
Dimensions
287 lb (130 kg)
Power requirements
110V - 127V, 15A or 220 - 240V, 10A
Included accessories and supplies
HP pm1000 Microlab Printer Expansion Kit (optional)
Output products
4 inches x 6 inches photos
Dimensions
28 inches x 30 inches x 32 inches without wheels
28 inches x 30 inches x 35 inches with wheels
409 lb
Power requirements
120 V, 60 Hz, 15 A dedicated
Power consumption
11.0 A peak
Print technology
Proprietary HP thermal inkjet 6-ink technology
Inks
6 water-fast inks
Paper size
4 inches x 6 inches
Paper capacity
3,300 sheets
Throughput
700 prints per hour
HP Photosmart Studio CD Expansion Kit (optional)
Output products
Printing technology
Rimage 2000i, featuring HP thermal inkjet technology
Dimensions
20.52 inches x 16.75 inches x 20.25 inches
60lb
Power requirements
110–240V auto ranging, 2.7A
HP Photo Center Consumer Scanner (optional)
Scan resolution
Color bit depth/grayscale levels
96-bit/256
Maximum document scan size
8.5 inches x 12.3 inches (216 x 311mm)
Connectivity
Hi-Speed USB (compatible with USB 2.0 specifications)
Product dimensions
Maximum: 11.93 inches x 20 inches x 4.25 inches (303x508x108mm)
Power specifications
External power adapter, Universal AC adapter: 100-240 VAC, 50/60Hz input
24 VDC,1500 mA, 36 watts output
Energy Star efficiency level IV
Power consumption: 25 watts maximum
HP Standard Film Scanner Expansion Kit (optional)
Strip length
Rolls up to 40 images, as well as strips down to two frames
DX code
Automated for 35 MM film
Output color space
16-bit linear transmittance
Resolution
Up to 2000 x 3000, base 16 (default @ 1400x2100)
Power requirements
Dimensions with catch tray
12.5 inches x 13.5 inches x16 inches (317x343x406mm)
Computer hardware
HP 7700 computer
