HP Compaq t5630 Thin Client Product Specifications
Product description
The HP t5630 Thin Client delivers great value with a familiar Windows experience at the right performance level. Microsoft Windows XP Embedded SP2 operating system combined with a full-featured browser, Enhanced Write Filter, Symantec Endpoint Protection, terminal emulations, native dual monitor and widescreen support make the HP t5630 the optimum choice for business environments requiring a cost-effective thin client with flexibility and power.
Product features
Feature
VIA VX800 north/south bridge unified chip
Processor
VIA Eden 1 GHz
Memory
Flash 1 GB
System Memory Up to 1 GB (64 MB reserved for video)
Graphics
VIAChrome9 HC3 Integrated Graphics Processor
The resolutions your monitor displays and the multi-display modes (i.e., clone, spanning, extended/independent) supported in ICA, RDP or locally may vary. The graphics controller supports these resolutions:
Input/Output/ Peripheral Support
Keyboard: Keyboard (USB or PS/2)
Mouse: Mouse (USB or PS/2)
Printer: Local and/or network printers (RDP, ICA, LPD).
Video:
  • VGA-type video output (DB-15)
  • DVI-D digital video output
I/O ports and connectors
6 USB 2.0 ports, 1 serial, 1 parallel, 2 PS/2, 1 RJ45, 1 VGA, 1 DVI-D, 1 headphone, 1 microphone
Terminal Server Protocols
  • Citrix ICA
  • RDesktop
Power Supply
50 W External
Communications
Features
Communication
Belkin USB Wireless 802.11b/g
Touch Screens
  • ELO Touch 1529L Flat Panel.
  • HP L5006tm LCD Touchscreen.
Security
  • HP USB Smartcard Keyboard
  • SCM USB Smart Card Reader
  • HP/Kensington Cable Lock
Audio/Visual
Features
Audio
  • Output: Internal amplified speaker, 1/8-inch mini-jack, 24-bit stereo, 192-kHz sample rate
  • Input: 1/8-inch microphone mini-jack, 20 bit stereo, 96 kHz sample rate
Visual
Physical specifications
Features
Dimensions (HxWxD)
Without stand 8.25 x 2.05 x 8.5 inches (209.55 x 52.07 x 215.90 mm)
With stand 8.65 x 2.05 x 8.5 inches (219.70 x 52.07 x 215.90 mm)
3.40 lbs (1.54 kg)
Power*
Operating voltage range : 100-240 VAC
Rated line frequency: 50-60 Hz
* The actual power consumption at your location could vary and is dependent on many factors including but not limited to software load on the thin client, attached peripherals, and environmental factors.
Environmental
Operating temperature range:
  • 50 degree to 104 degree F (10 degree to 40 degree C).
Non-operating temperature range:
  • –22 degree to 140 degree F (–30 to 60 degree C).
Humidity (non-condensing)
Operating: 10% to 90%.
Non-operating:5% to 95%.
Software/OS
Feature
Operating System
  • Microsoft Windows XP Embedded SP2
Server OS Compatibility/ Support
  • Citrix Presentation Server
  • Windows 2000/2003 Server families
  • Windows 2008 Server
  • Windows 2000/2003 Server Terminal Services
  • Windows 2000 Advanced Server, Windows 2000 Advance Server Terminal Services
  • VMware Virtual Desktop Infrastructure using RDP
Session Allocation Managers/Session Brokers
  • HP Session Allocation Manager (SAM)
  • Citrix XenDesktop DDC broker
  • VMware VDM broker
  • Leostream Desktop Connection Broker (contact vendor directly for broker sales and support)
  • Provision Networks (Quest) Virtual Access Broker (contact vendor directly for broker sales and support)
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
