HP Compaq t5545 Thin Client - Specifications
Hardware Specifications
Features
Dimensions (HxWxD)
Without stand 8.25 x 2.05 x 8.5 inches (209.55 x 52.07 x 215.90 mm)
With stand 8.65 x 2.05 x 8.5 inches (219.70 x 52.07 x 215.90 mm)
3.40 lbs (1.54 kg)
Power*
Operating voltage range : 100-240 VAC
Rated line frequency: 50-60 Hz
* The actual power consumption at your location could vary and is dependent on many factors including but not limited to software load on the thin client, attached peripherals, and environmental factors.
Environmental
Operating temperature range:
  • 50 degree to 104 degree F (10 degree to 40 degree C).
Non-operating temperature range:
  • –22 degree to 140 degree F (–30 to 60 degree C).
Humidity (non-condensing)
Operating: 10% to 90%.
Non-operating:5% to 95%.
Communications
Features
Communication
Belkin USB Wireless 802.11b/g
Touch Screens
  • ELO Touch 1529L Flat Panel.
  • HP L5006tm LCD Touchscreen.
Security
  • HP USB Smartcard Keyboard
  • SCM USB Smart Card Reader
  • HP/Kensington Cable Lock
Audio/Visual
Features
Audio
  • Output: Internal amplified speaker, 1/8-inch mini-jack, 24-bit stereo, 192-kHz sample rate
  • Input: 1/8-inch microphone mini-jack, 20 bit stereo, 96 kHz sample rate
Visual
  • VGA-type video output
  • DVI-D digital video output
