    Fix HP Printer issue on macOS
HP Designjet Z3200PS Printer Series - Printer software
Printer software
The following software is provided with your printer:
  • The PCL3 raster printer driver
  • The PostScript printer driver
  • The HP Printer Utility, see Access the HP Printer Utility, allows you to:
    • Manage the printer including color with the HP Color Center
    • Manage the job queue, see Job queue management
    • View the status of the ink cartridges, the printheads and the paper
    • View job accounting information, see Retrieving printer usage information
    • Update the printer's firmware, see Update the firmware
    • Access the HP Knowledge Center
    • Change various printer settings (in the Settings tab)
    • Perform calibrations and troubleshooting
  • The Embedded Web Server runs in the printer and enables you to use a Web browser on any computer to check ink levels and printer status, see Access the Embedded Web Server
  • The Advanced Profiling Solution, included on a separate CD, to be installed after other HP software (drivers and the HP Printer Utility)
