HP Compaq nx6110 Notebook PC - Removing and Replacing the Keyboard
This document is provided to assist in removing and replacing the Keyboard for the HP Compaq nx6110 Notebook PC.
Minimum skill level
Tools required
  • P1 Phillips-head screw driver
  • T8-9 mm screw driver
Parts required
The replacement part number will vary depending on the Keyboard that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
101/102-key compatible keyboard (Black) - Industry standard full-pitch layout, isolated inverted-T cursor control keys, integrated numeric keypad, instant-access hotkeys - 19.0mm x 19.0mm key pitch, 2.5mm stroke - Includes ribbon cable
378248-xx1 (Original)
No
101/102-key compatible keyboard with Point Stick (Black) - Industry standard full-pitch layout, isolated inverted-T cursor control keys, integrated numeric keypad, instant-access hotkeys - Includes ribbon cable
398609-xx1 (Original)
No
The part number will vary based on the country. Click here for a list of country specific keyboard spare part numbers.
Summary of instructions
To view a video demonstrating the procedure for removing the Keyboard, click on the link below. Or use the product video listing on the HP Services Media Library, then select Keyboard from the menu on the upper left hand side of the screen.
Right-click on the video link above to open in a new window/tab.
Keyboard removal
  2. Loosen the captive P1 Phillips-head screw that secures the memory/Mini PCI cover to the bottom of the notebook.
  3. Use your finger or a flat-bladed tool to lift the outside edge of the memory/Mini PCI cover and remove it.
  4. Remove the two T8-9 mm screws that secure the keyboard to the base enclosure.
  5. Turn the notebook right side up and open the display panel fully.
  6. Slide the four plastic locking tabs toward the bottom edge of the keyboard to unlock the keyboard from the LED switch cover.
  7. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and then place it upside down on the top cover.
  8. Using minimal force, lift the locking bar to unlock the keyboard ZIF connector on the system board.
    Use care to prevent damaging the ZIF connector and ribbon cable.
  9. Remove the keyboard ribbon cable from the ZIF connector and remove the keyboard.
Keyboard replacement
  1. After ensuring that the locking bar on the keyboard ZIF connector is unlocked, place the keyboard right side up on the top cover.
  2. Insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
    Use care to prevent damaging the keyboard ribbon cable.
  3. Push the locking bar down to lock the keyboard ZIF connector on the system board.
  4. Toe the tabs on the bottom edge of the keyboard into the top cover.
  5. Press the keyboard flat and slide the four plastic locking tabs toward the rear of the notebook to lock the keyboard to the LED switch cover.
  6. Close the display panel and turn the notebook upside down.
  7. Replace the two T8-9 mm screws that secure the keyboard to the base enclosure.
  8. Toe the memory/Mini PCI cover into the enclosure.
  9. Tighten the captive P1 Phillips-head screw.
Country: Flag Serbia
