HP Compaq nw8440 Mobile Workstation - Removing and Replacing the Video Heat Sink/Fan Assembly
This document is provided to assist in removing and replacing the Video heat sink/fan assembly for the HP Compaq nw8440 Mobile Workstation.
Tools required
P0 Phillips-head screw driver
Parts required
The replacement part number will vary depending on the Video heat sink/fan assembly that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Heat sink for CPU - Includes thermal paste
416408-001 (Modified)
No
Cooling fan with cover
416409-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the Video heat sink/fan assembly, click on the link below. Or use the product video listing on the HP Services Media Library, then select Video heat sink/fan assembly from the menu on the upper left hand side of the screen.
Right-click on the video link above to open in a new window/tab.
Video heat sink/fan assembly removal
  2. Disconnect the fan cable from the system board.
  3. Loosen the two captive P0 Phillips-head screws, labeled 1 and 2 on the video heat sink, that secure the video heat sink/fan assembly to the thermal plate.
  4. Loosen the two captive P0 Phillips-head screws, labeled 3 and 4 on the fan, that secure the video heat sink/fan assembly to the base enclosure.
  5. Lift the inside edge of the video heat sink/fan assembly and slide it out of the base enclosure.
Video heat sink/fan assembly replacement
Before replacing the video heat sink/fan assembly, the thermal grease should be replaced. The thermal grease should be replaced every time the video heat sink/fan assembly is removed.
  1. Toe the outside edge of the video heat sink/fan assembly into the base enclosure.
  2. Lower the inside edge of the video heat sink/fan assembly into position.
  3. Tighten the two captive P0 Phillips-head screws, labeled 1 and 2 on the video heat sink, that secure the video heat sink/fan assembly to the thermal plate.
  4. Tighten the two captive P0 Phillips-head screws, labeled 3 and 4 on the fan, that secure the video heat sink/fan assembly to the base enclosure.
  5. Reconnect the fan cable to the system board.
Country: Flag Serbia
