HP Compaq nw8440 Mobile Workstation - Removing and Replacing the Keyboard
This document is provided to assist in removing and replacing the Keyboard for the HP Compaq nw8440 Mobile Workstation.
Minimum skill level
The End-User should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Tools required
T8-9 mm screw driver
Parts required
The replacement part number will vary depending on the Keyboard that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Keyboard with point stick - Includes keyboard cable and point stick cable
416416-xx1 (Modified)
No
Keyboard without point stick - Includes keyboard cable
416417-xx1 (Modified)
No
The part number will vary based on the country. Click here for a list of country specific keyboard spare part numbers.
Summary of instructions
To view a video demonstrating the procedure for removing the Keyboard, click on the link below. Or use the product video listing on the HP Services Media Library, then select Keyboard from the menu on the upper left hand side of the screen.
Right-click on the video link above to open in a new window/tab.
Keyboard removal
  2. Remove the two T8-9 mm screws that secure the keyboard to the base enclosure.
    Screw location is indicated by the appropriate icon.
  3. Turn the notebook right side up and open the display panel fully.
  4. Slide the four plastic locking tabs toward the bottom edge of the keyboard to unlock the keyboard from the switch cover.
  5. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and then place it upside down on the top cover.
  6. Using minimal force, lift the locking bar to unlock the keyboard ZIF connector on the system board.
    Use care to prevent damaging the ZIF connector and ribbon cable.
  7. Remove the keyboard ribbon cable from the ZIF connector.
    The nw8440 notebooks also have a pointing stick.
  8. Using minimal force, lift the locking bar to unlock the pointing stick ZIF connector on the system board.
  9. Remove the pointing stick ribbon cable from the ZIF connector and remove the keyboard.
Keyboard replacement
  1. Place the keyboard upside down on the top cover.
  2. Insert the pointing stick ribbon cable into the pointing stick ZIF connector on the system board (on nc8430 and nw8440 notebooks only).
    Use care to prevent damaging the pointing stick ribbon cable.
  3. Push the locking bar down to lock the pointing stick ZIF connector on the system board.
  4. Insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
    Use care to prevent damaging the keyboard ribbon cable.
  5. Push the locking bar down to lock the keyboard ZIF connector on the system board.
  6. Toe the tabs on the bottom edge of the keyboard into the top cover.
  7. Press the keyboard flat and slide the four plastic locking tabs toward the rear of the notebook to lock the keyboard to the switch cover.
  8. Close the display panel and turn the notebook upside down.
  9. Replace the two T8-9 mm screws that secure the keyboard to the base enclosure.
Country: Flag Serbia
