HP Compaq nw8440 Mobile Workstation - Removing and Replacing the Hard Disk Drive
This document is provided to assist in removing and replacing the Hard disk drive for the HP Compaq nw8440 Mobile Workstation.
Minimum skill level
Tools required
P0 Phillips-head screw driver
Parts required
The replacement part number will vary depending on the Hard disk drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
120 GB SATA hard disk drive - 5,400 RPM - Includes frame
416414-001 (Modified)
Yes
100 GB SATA hard disk drive - 7,200 RPM - Includes frame
416415-001 (Modified)
Yes
100 GB SATA hard disk drive - 5,400 RPM - Includes frame
413853-001 (Modified)
Yes
80 GB SATA hard disk drive - 7,200 RPM - Includes frame
417507-001 (Modified)
Yes
80 GB SATA hard disk drive - 5,400 RPM - Includes frame
413852-001 (Modified)
Yes
60 GB SATA hard disk drive - 5,400 RPM - Includes frame
413851-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the Hard disk drive, click on the link below. Or use the product video listing on the HP Services Media Library, then select Hard disk drive from the menu on the upper left hand side of the screen.
Right-click on the video link above to open in a new window/tab.
Hard disk drive removal
  2. Loosen the two captive P0 Phillips-head screws that secure the hard disk drive cover to the bottom of the notebook.
  3. Use your finger or a flat-bladed tool to lift the inside edge of the hard disk drive cover and remove it.
  4. Loosen the captive spring-loaded P1 Phillips-head screw that secures the hard disk drive.
  5. Grasp the Mylar tab and pull the hard disk drive toward the outside edge of the base enclosure to disconnect the hard disk drive from the system board connector.
  6. Lift the hard disk drive out of the bay and remove.
  7. Place the hard disk drive in a static dissipative bag.
Hard disk drive replacement
  1. Remove the hard disk drive from the static dissipative bag.
  2. Place the hard disk drive into the hard disk drive bay.
  3. Push the hard disk drive toward the inside of the base enclosure until the connector is seated.
  4. Tighten the captive spring-loaded P1 Phillips-head screw that secures the hard disk drive.
  5. Toe the hard disk drive cover into the enclosure.
  6. Tighten the two captive P0 Phillips-head screws.
Country: Flag Serbia
