This document is for HP Officejet, Photosmart, and PSC Printers manufactured before 2010, running Windows XP only.
When you try to print over your Local Area Network (LAN), the product does not print and the following message displays on the computer: 'The printer spooler was unable to connect to your printer. This can be caused by your printer being unplugged, or being connected to a VPN, which will block your access to your local network.'
This error message can occur when printing over a wired (Ethernet) or wireless network.
