    Looking for Site Help?
HP Color LaserJet CP2020 Series Printer - Manage supplies
Supplies life
The print cartridge use HP ColorSphere toner. For information about the number of pages the cartridges can print, see www.hp.com/go/pageyield. Actual yield depends on specific use.
Print-cartridge storage
Do not remove the print cartridge from its package until you are ready to use it.
To prevent damage to the print cartridge, do not expose it to light for more than a few minutes.
HP policy on non-HP print cartridges
Hewlett-Packard Company cannot recommend the use of non-HP print cartridges, either new or remanufactured.
Any damage caused by a non-HP print cartridge is not covered under the HP warranty and service agreements.
To install a new HP print cartridge, see Replace print cartridges. To recycle the used cartridge, follow the instructions included with the new cartridge.
HP fraud hotline and Web site
Call the HP fraud hotline (1-877-219-3183, toll-free in North America) or go to www.hp.com/go/anticounterfeit when you install an HP print cartridge and the control-panel message says the cartridge is non-HP. HP will help determine if the cartridge is genuine and take steps to resolve the problem.
Your print cartridge might not be a genuine HP print cartridge if you notice the following:
  • You are experiencing a high number of problems with the print cartridge.
  • The cartridge does not look like it usually does (for example, the orange pull tab is missing, or the packaging differs from HP packaging).
Print when cartridge has reached estimated end of life
An Order Supplies message appears when a print cartridge is nearing the end of its life. A Replace supplies message appears when the print cartridge has reached its estimated end of life. To ensure optimal print quality, HP recommends replacing a print cartridge when the Replace supplies message appears. Print-quality problems can occur when using a cartridge that has reached its estimated end of life, resulting in waste of print media and toner from other cartridges. Replacing a print cartridge when the Replace supplies message appears can prevent this waste.
The Auto continue feature in HP ToolboxFX allows the product to continue using a print cartridge that has reached the recommended replacement point.
  warning:
Using the Auto continue feature can result in unsatisfactory print quality.
  warning:
All print defects or supply failures incurred when an HP supply is used in cartridge-out-override mode will not be considered to be defects in materials or workmanship in the supply under the HP Print Cartridge Warranty Statement. For warranty information, see Print cartridge limited warranty statement.
You can enable or disable the Auto continue feature at any time, and you do not have to re-enable it when you install a new print cartridge. When the Auto continue feature is turned on, the product automatically continues printing when a print cartridge reaches the recommended replacement level. A Replace Supplies Override In Use message appears while a print cartridge is being used in override mode. When you replace the print cartridge with a new supply, the product deactivates the override mode until another print cartridge reaches the recommended replacement level.
Enable or disable the Cartridge out override feature
  1. Open HP ToolboxFX.
  2. Click the Device Settings folder, and then click System Setup.
  3. Next to Auto continue select On to enable the feature. Select Off to disable it.
Enable or disable the Cartridge out override feature from the control panel
  1. On the control-panel menu, press OK.
  2. Use the Left arrow () or the Right arrow () button to select System setup, and then press OK.
  3. Use the Left arrow () or the Right arrow () button to select Print quality, and then press OK.
  4. Use the Left arrow () or the Right arrow () button to select Replace supplies, and then press OK.
  5. Select Override out to enable the feature. Select Stop at out to disable it.
Country: Flag Serbia
