HP Compaq dx2300 Microtower PC - Removing and Replacing the Hard drive
This document is provided to assist in removing and replacing the Hard drive for the HP Compaq dx2300 Microtower PC.
Minimum skill level
Tools required
Torx-15 screwdriver.
Parts required
The replacement part number will vary depending on the Hard drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
80 GB SATA 2 (3 Gb/s) hard drive - 7,200 RPM, 3.5 inches form factor, 1 inch high
440754-001 (Modified)
Yes
160 GB SATA 2 (3 Gb/s) hard drive - 7,200 RPM, 3.5 inches form factor, 1 inch high
440499-001 (Modified)
Yes
250 GB SATA 2 (3 Gb/s) hard drive - 7,200 RPM, 3.5 inches form factor, 1 inch high
440747-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the Hard drive, click on the link below. Or use the product video listing on the HP Services Media Library then select Hard drive from the menu on the upper left hand side of the screen.
Click here to view the Hard drive removal video (right-click on the link to open in a new window/tab).
Hard drive removal
  2.   note:
    This system supports SATA hard drives only. You do not have to select a cable setting.
  3. Disconnect the power and data cables from the drive.
  4. Remove the four Torx-15 screws that secure the drive to the drive cage.
  5. Slide the drive out of the drive cage.
Hard drive replacement
  1. Slide the drive into the drive bay until the screw holes on the drive and drive cage are aligned.
  2. Replace the four Torx-15 screws to secure the drive to the drive cage.
  3. Connect the power and data cables to the drive.
Country: Flag Serbia
