HP LaserJet Multifunction Printers - Automatic Daylight Saving Time
Automatic Daylight Saving Time adjustment has been added on the LaserJet Multifunction Printers (MFPs). A correct clock setting is not required for MFP operation. Some authentication methods, such as Kerberos, require a correct Universal Time setting, but do not care about Daylight Saving Time. The primary reason users might want to adjust for Daylight Saving Time is to have the correct time stamps on faxes, event logs, and so forth.
Details
The different methods of configuring the Automatic Daylight Saving Time are the following:
1. The MFP would prompt the user to input the Time Zone and adjust Daylight Saving after firmware upgrade. The screens after the upgrade will be as follows:
LaserJet 4345MFP, LaserJet 9040/50MFP, Color LaserJet 4730MFP, Color LaserJet 9500MFP and Digital Sender 9200c:
LaserJet M4345MFP, LaserJet 3027/35MFP, LaserJet 5025/35MFP, Color LaserJet CM4730MFP and Digital Sender 9250c:
2. Use the embedded web server to configure Date and Time, the option is available under Settings -> Date & Time - > Advanced.
3. Use Web JetAdmin.
This is available with the following firmware versions:
  • OZ 8/9 Products - 0x.081.x and later
  • M Series MFPs - x.031.x and later
