Adding or Replacing an Expansion Card in HP Pavilion Elite HPE-100 Series Desktop PCs
This document pertains to HP desktop computers with the following computer case:
Image of the HP Elite Desktop PC
Before you begin
  • Turn off the computer, disconnect all cables, and transfer the computer to a clear, flat, stable work surface over a non-carpeted floor.
  warning:
Video overview
For best quality on dial-up connections, wait until the video has fully loaded before viewing.
Step 1: Preparing the PC
Before starting, if you are adding an expansion card that will replace a function that comes from the motherboard (video, sound, network), disable the on-board function and select the correct BIOS setting in BIOS Setup before attempting to install the new card. Do so as follows:
Step 1. Turn on the PC and immediately begin pressing the F10 key repeatedly until a BIOS Setup screen appears.
Step 2. Press the Right arrow key to select the Advanced page.
Step 3. Find and select the setting that matches the type of card you are installing. Examples of possible selections for an award BIOS are:
  • Video: Primary Video Adapter
  • Audio: Audio Codec
  • Network: Onboard LAN
The selections on your PC may not be the same as those given as examples If this is the case, the selections will be very similar. Select the setting that most closely matches the type of card you are installing.
Figure : On-board Video example
BIOS Screen
Step 4. Press enter to open a list of options for the selected function.
Step 5. Select the option that best applies to the expansion card that you will be installing. Examples of what to select:
  • Video: AGP, PCI or PCI-E depending on the type of video card you are installing.
  • Audio: Select disabled if you are installing an audio card. This disables on-board audio, helps prevent conflicts, and saves resources for your new card.
  • Network: Select disabled if you are installing a network card. This disables on-board LAN, helps prevent conflicts, and saves resources for your new card.
    Illustration of PCI-E x 16 expansion card, AGP card, and PCI card
  1. PCI-E (x16) card
  2. AGP card
  3. PCI card
Step 6. Once you have made your selection by pressing the Enter key, press F10 to Save the settings and exit.
Step 7. If you are using Windows, wait until Windows fully loads and then shut down the computer from the Start menu.
Illustration showing shutdown procedure from Start menu
Step 2: Removing the expansion card or slot cover
Use the steps in this section to remove the slot filler or an existing expansion card from the computer. The slot filler needs to be removed before an expansion card can be installed in a previously unused slot.
  warning:
The expansion card slots are located at the bottom rear of the computer.
Image of the location of the expansion cards at the bottom rear of the computer
Step 1. Remove the side cover.
For more information about removing the side cover, refer to the HP support document Opening the PC Case.
Image of the side cover removal
Step 2. Unplug any cables attached to the card.
Make sure that you can remember the connection locations. If necessary, attach labels to the cables and connectors to help reconnect them later.
Image of cables on an example expansion card
Step 3. Remove the screw that secures the expansion card .
Or
If you are adding an expansion card to an empty slot, remove the screw that secures a slot cover and pull the slot cover out.
    Image of the retaining screws
  1. Screw that retains expansion card
  2. Screw that retains slot cover
Step 4. If removing a graphics card, find and release its retaining latch.
Illustration of expansion card retaining latch
Step 5. Gently pull the edges of the expansion card and release it from the expansion slot.
Animated image of removing an expansion card
Step 3: Installing an expansion card
Use the steps in this section to install a new expansion card.
Step 1. Insert the expansion card into the slot until it is seated.
Animated image of inserting an expansion card
Step 2. Insert the retaining screw to secure the expansion card in the computer.
Image of the retaining screw on two separate expansion cards
Step 3. Connect any required cables (that were disconnected from the previous card).
Step 4. Replace the side panel, reconnect the cables, and turn on the computer.
For more information about replacing the side cover, refer to the HP support document Opening the Case.
Step 5. If using Windows, wait until Windows finds and configures the new expansion card.
Illustration of the Found New Hardware message
