HP MediaSmart Server - Microsoft Windows Home Server PowerPack 1
This document applies to HP MediaSmart Server EX470 and EX475.
Check to see if Microsoft Windows Home Server PowerPack 1 is Installed
To check if PowerPack 1 has been installed :
  1. Double-click the Windows Home Server icon Windows Home Server icon in the task tray.
  2. Log on to the Windows Home Server.
  3. On the Windows Home Server Console, click the Settings tab and then click Resources in the left panel. In our example PowerPack 1 has been installed, look at the section circled in red.
    Figure : Resources
Installing Microsoft Windows Home Server PowerPack 1 before August 12,2008
Starting July 21st this will be available as a manual download, then on August 12th it will be available through Windows Update.
If Microsoft Windows Home Server PowerPack 1 has not been installed go to http://www.microsoft.com/downloads/, enter 944289 in the search all downloads field and press Go. Download Windows Home Server PowerPack 1; installation instructions are included that page.
Installing Microsoft Windows Home Server PowerPack 1 after August 12, 2008
If the HP MediaSmart Server is purchased after August 12th, Microsoft Windows Home Server PowerPack 1 will NOT install as part of the initial setup.
After August 12, 2008 you will have 2 options for installing Microsoft Windows Home Server PowerPack 1:
  1. or
Manual Download of Microsoft Windows Home Server PowerPack 1
  3. On the Windows Home Server Console, click the Settings tab and then click General in the left panel.
  4. Click Update Now and follow the instructions from Microsoft to install Microsoft Windows Home Server PowerPack 1.
    Figure : General Settings
Install Microsoft Windows Home Server PowerPack 1 Using Windows Update
  1. If Windows Update is turned on, Microsoft Windows Home Server PowerPack 1 will download and install overnight during the next maintenance window; the default time for the maintenance window is Midnight - 6 AM.
  2. If Windows Update is not turned on. You will need to manually download the Microsoft Windows Home Server PowerPack 1. Click Microsoft Windows Home Server PowerPack 1 for more information.
