HP iPAQ 900 Business Messenger Series - Configuring the Display Settings
You can configure the display settings to:
  • Change the display language
  • Customize the Today screen
  • Recalibrate the display screen
Changing the display language
Follow these steps to change the display language.
  1. Tap Start > Settings > System.
  2. Tap Regional Settings.
  3. Select the desired language from the list.
  4. Tap ok to return to the Settings screen.
Customizing the Today screen
Follow these steps to customize the Today screen.
  1. Tap Start > Settings > Personal.
  2. Tap Today > Appearance tab.
  3. Select the required theme for the background of the Today screen.
  4. Tap ok. The selected theme displays as the Today screen's background.
  5. Tap Today > Items tab.
  6. Select the items to appear on the Today screen.
  7. To customize the items further, select an item and then tap Options...
    The Options... is not available for all items.
  8. Tap ok. The selected items appear on the Today screen.
Recalibrating the display screen
Follow these steps to recalibrate the display screen.
  2. Tap the Screen icon.
  3. On the Alignment tab, tap the Align Screen button and follow the on-screen instructions.
