Use the Bluetooth technology of your HP iPAQ 900 Business Messenger to connect to a Bluetooth enabled headset.
- ${title}
- ${title}
- ${title}
- ${title}
HP iPAQ 900 Business Messenger Series - Connecting to a Bluetooth Enabled Headset
Turning on Bluetooth
Follow these steps to turn on Bluetooth.
Tap Start > Settings > Connections > Wireless Manager.
Tap the Bluetooth button to turn on the Bluetooth connection.Figure : Wireless Manager screen
Connecting to a Bluetooth enabled headset
Follow these steps to connect to a Bluetooth enabled headset.
For the steps to make your Bluetooth headset discoverable, refer to your headset product guide.
Place the Bluetooth enabled headset near the device.
Tap Start > Settings > Connections > Bluetooth.
Tap Add new device....Figure : Bluetooth Devices screen
From the Select a Bluetooth Device list, select the appropriate Bluetooth enabled headset. The device tries to connect to the headset automatically.
If prompted for a passcode, refer to your headset product guide to find the appropriate passcode.
Tap Next.
Follow the on-screen instructions to establish a connection between the headset and the device.
note:The device stores the Bluetooth headset settings after connecting for the first time. To reconnect, tap Start > Settings > Connections > Wireless Manager > Menu > Bluetooth Settings. Tap and hold the headset name to which you want to connect and then select the services you want to use.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
