Document ID: c01492658
Version: 1
HP Notebook PCs - Notebook PC Hard Drive With HP ProtectTools Drive Encryption Not Accessible After Performing Recovery Using OSDVD
Release date : 26-Jun-2008
Last updated : 26-Jun-2008
DESCRIPTION
An encryption error may display on encrypted hard drives using HP ProtectTools Drive Encryption after performing a recovery process using the OSDVD.
Encryption error: SafeBoot has been corrupted (Error 92h)
The hard drive will not be accessible.
SCOPE
The specific notebook PCs affected by this issue are listed in the Hardware Platforms Affected section at the bottom of this advisory.
RESOLUTION
To resolve this issue, perform one of the following:
Reformat hard drive
This process will remove the SafeBoot MBR (Master Boot Record) and then re-image the hard drive.
Data will not be lost.
  1. Insert the OSDVD (Disc shipped with the notebook PC) into the notebook PC optical disc drive.
  2. Restart the notebook PC to boot to the OSDVD.
  3. Click Next and then select Yes to reset the system to factory settings. Click Next.
  4. The Recovery process will proceed. Follow the on screen instructions.
Repair my computer
This process repair the MBR (Master Boot Record)
  3. Click Next and then select Repair My Computer.
  4. Follow the on screen instructions.
  5. At the Recovery Options main menu, select Command Box.
  6. Run BOOTREC /FIXMBR.
  7. Reboot the notebook PC.
Hardware platforms affected : HP Compaq 2230s Notebook PC, HP Compaq 6530s Notebook PC, HP Compaq 6730b Notebook PC, HP Compaq 6730s Notebook PC, HP Compaq 6735b Notebook PC, HP Compaq 6735s Notebook PC, HP Compaq 6830s Notebook PC, HP EliteBook 2530p Notebook PC, HP EliteBook 2730p Notebook PC, HP EliteBook 8530p Notebook PC, HP EliteBook 8530w Mobile Workstation, HP EliteBook 8730w Mobile Workstation
Support Communication Cross Reference ID : IA01491704
