    Looking for Site Help?
HP xw9300 Workstation - Removing and Replacing the PCI Cards
This document is provided to assist in removing and replacing the PCI Cards for the HP Workstation xw9300.
Minimum skill level
The End-User should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Parts required
The replacement part number will vary depending on the PCI Cards that is being replaced. If a part is listed as 'Yes' under 'Requires Return' then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
HP FireWire IEEE 1394a 3-Port PCI card
393308-001
No
PCI Express (PCIe) NVIDIA Quadro NVS 285 graphics card - With 128 MB DDR SDRAM
398685-001
Yes
NVIDIA Quadro FX 1440 PCI-Express 128 MB graphics card
395817-001
Yes
NVIDIA Quadro FX 540 PCI-Express 128 MB graphics card
398683-001
Yes
NVIDIA Quadro4 280 XGL PCI-E (x16) graphics card - With 64 MB DDR SDRAM
365934-001
Yes
For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labeled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labeled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the PCI Cards, click on the link below. Or use the product video listing on the HP Services Media Library, then select PCI Cards from the menu on the upper left hand side of the screen.
Click here to view the PCI Cards removal video (right-click on the link to open in a new window/tab).
PCI Cards removal
  2. Remove the access panel.
  3. Disconnect any cables attached to the expansion card.
  4. Press the two tabs on the side of the expansion card tensioner to release it from the chassis, then rotate the tensioner away from the expansion card and out of the chassis.
  5. Press down on the two green expansion card retainer clips until they release.
  6. Rotate the expansion card retainer up against the rear of the chassis.
    Slot 1 and slot 3 are PCI Express slots with locking tabs. Push out and hold the locking tab while lifting expansion cards from these slots. On the xw9300 only, the PCI-E locking tabs are on the opposite side of the card from the tab orientation on the xw6200 or xw8200.
  7. Lift straight up on the expansion card to remove it from the slot.
  8. Place the expansion card in a static dissipative bag.
PCI Cards replacement
  1. Remove the expansion card from the static dissipative bag.
  2. Align the connectors on the expansion card with the slot on the system board.
  3. Press down on the expansion card until it is fully seated in the slot on the system board.
  4. Rotate the expansion card retainer down over the expansion card bulkhead.
  5. Press in on the two green expansion card retainer tabs on the rear of the chassis until they lock into place.
  6. Hook the two tabs on the expansion card tensioner into the chassis slots and rotate the tensioner into position.
  7. Ensure that the tensioner is correctly aligned with the expansion card, then press down on the tensioner until the retainer tabs lock into place.
  8. Reconnect any cables to the expansion card.
Country: Flag Serbia
