HP Compaq dc7700 Small Form Factor PC - Removing and Replacing the PCI riser card
This document is provided to assist in removing and replacing the PCI riser card for the HP Compaq dc7700 Small Form Factor PC.
Minimum skill level
The End-User should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Tools required
Torx #15 (T-15) screwdriver.
Parts required
The replacement part number will vary depending on the PCI riser card that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Riser board assembly - Includes expansion/riser card and computer backwall
394213-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the PCI riser card, click on the link below. Or use the product video listing on the HP Services Media Library then select PCI riser card from the menu on the upper left hand side of the screen.
Right-click on the video link above to open in a new window / tab.
PCI riser card removal
  2. Remove the two Torx-15 screws that secure the riser card to the PCI card cage.
  3. Remove the card from the cage.
PCI riser card replacement
  1. Align the riser card with the screw holes on the card cage.
  2. Replace the two screws that secure the riser card to the PCI riser cage.
