HP Compaq dc7700 Small Form Factor PC - Removing and Replacing the PCI card
This document is provided to assist in removing and replacing the PCI card for the HP Compaq dc7700 Small Form Factor PC.
Minimum skill level
Tools required
Torx #15 (T-15) screwdriver.
Parts required
The replacement part number will vary depending on the PCI card that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
ATI Radeon X1300 PCI-Express graphics board - Video board with 256 MB DDR SDRAM memory, one DVI-I digital display output, and one 4-pin (F) mini-DIN (S-video) TV output
413023-001 (Modified)
Yes
NVIDIA Quadro4 280 XGL PCI (x8) graphics card - Professional 2D low profile graphics board with 64 MB DDR SDRAM, dual 350 MHz RAMDAC, and one DMS-59 high density output connector - ATX form factor
398686-001 (Modified)
Yes
PCIe interface card - Feature connector for digital visual interface (DVI-D) and serial digital video output (SDVO)
398333-001 (Modified)
Yes
HP FireWire IEEE 1394a 3-Port PCI card
393308-001 (Modified)
Yes
IEEE-1394 (FireWire) interface PCI board
393307-001 (Modified)
Yes
Intel Pro/1000 PT Gigabyte Ethernet PCIe network interface card - Has one RJ-45 connector
398754-001 (Modified)
Yes
Broadcom NetXtreme PCIe 10/100/1000 Base-T copper based gigabit Ethernet LAN adapter
430654-001 (Modified)
Yes
Agere Systems PCI SoftModem - High-speed 56 Kbps, V.92 modem card - Has one (F) RJ-11 output connector
398661-001 (Original)
Yes
DVI-I to VGA adapter - From a (M) DVI-I connector to a (F) 15-pin VGA connector
202997-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the PCI card, click on the link below. Or use the product video listing on the HP Services Media Library then select PCI card from the menu on the upper left hand side of the screen.
Right-click on the video link above to open in a new window / tab.
PCI card removal
    The HP Compaq Business Desktop dc7700 SFF supports low profile PCI cards only. The riser card cage is a configurable option that allows the use of full height PCI cards. This procedure shows the replacement of a PCI card which is inside the riser card cage only.
  2. Lift the handle on the PCI card cage and pull the cage straight up and out of the chassis. Lift the cage slowly in case there are cables attached to the PCI card.
  3. Disconnect any cables from the PCI card.
  4. Remove the Torx-15 screw that secures the PCI card to the card cage.
  5. Pull the PCI card out of the socket.
    If you are not replacing the PCI card with another card, cover the open slot in the PCI card cage with a metal slot cover to facilitate proper airflow and cooling of the system.
PCI card replacement
  1. If you are installing a new PCI card, remove the slot cover from the appropriate slot on the PCI card cage.
  2. Align the connectors on the PCI card with the slot on the riser card.
  3. Press down on the PCI card until it is fully seated in the slot.
  4. Replace the screw that secures the PCI card to the card cage.
  5. Connect any cables to the PCI card.
  6. Place the card cage in the chassis so that the two tabs on the side fit into the slots on the chassis side wall and the tab in the back fits over the chassis back wall.
  7. Press down on the PCI card cage until it is fully seated in the slot on the system board.
Parts return
