HP iPAQ 614 Business Navigator - How to Use GPS Navigation
This document describes how to use GPS navigation and browse Google maps on the HP iPAQ 614 Business Navigator.
An HP iPAQ 614 Business Navigator does not come with any built-in GPS navigation. However, it has a default GPS Utility called Assisted GPS. It should work with any Google Map that comes integrated in the unit. Updating the map version helps improve speed and connection reliability. This utility consumes low power.
By connecting to the Internet and using the Assisted GPS utility, it should be possible to use the Google maps on the iPAQ device to get a valid GPS signal.
Details
To launch GPS on the iPAQ, complete the following steps:
  1. Power on the iPAQ device.
  2. Start Google Maps.
  3. Click the menu entry for showing my location via GPS.
    Google Maps shows a search for GPS satellites.
  4. Download the latest Google Maps for better GPS functionality.
Scope:
