HP iPAQ 614c Business Navigator - How to Set the Alarms and Clocks
This document describes how to set the time (clock) and alarms on HP iPAQ.
Details
Complete the following steps to set the alarm:
  1. Tap Start > Settings > System > Clock & Alarms > Alarms.
  2. Tap <Description> to enter a name for the alarm.
  3. Tap the day of the week for the alarm. Multiple days can be selected by tapping each required day.
  4. Tap the time display that appears near the alarm name and set the time for the alarm.
  5. Tap the (Alarm) icon to specify the type of the alarm. A single sound or a repeating sound can be selected.
  6. For choosing to play a sound, tap the list next to the Play sound checkbox, and then tap the sound to be set.
Complete the following steps to set the time:
  1. Tap Start > Settings > System > Clock & Alarms > Time.
  2. Select Home to set the time zone, local time, and date when in your home country. Select Visiting to set these options while traveling.
