HP Compaq dc7700 Convertible Minitower PC - Removing and Replacing the Power switch/LED assembly
This document is provided to assist in removing and replacing the Power switch/LED assembly for the HP Compaq dc7700 Convertible Minitower PC.
Minimum skill level
Parts required
The replacement part number will vary depending on the Power switch/LED assembly that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Power switch - Includes power LED and cable
435257-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the Power switch/LED assembly, click on the link below. Or use the product video listing on the HP Services Media Library then select Power switch/LED assembly from the menu on the upper left hand side of the screen.
Click here to view the Power switch/LED assembly removal video (right-click on the link to open in a new window/tab).
  2. Disconnect the power switch/LED cable from the system board.
  3. Squeeze the sides of the power switch/LED housing and remove it from the chassis.
  4. Pull the assembly and cable out of the chassis.
Power switch/LED assembly replacement
  1. Thread the assembly cable through the opening in the chassis.
  2. Push the power switch/LED assembly into its slot in the chassis.
  3. Connect the power switch/LED cable to the system board.
Country: Flag Serbia
