HP ScanJet N9120 - HP Scanner Tools Utility scanner maintenance information
The Maintenance tab of the HP Scanner Tools Utility displays the scanner usage and maintenance history. You can use this tab to record scanner maintenance.
The Imprinter tab of the HP Scanner Tools Utility displays information about the scanner imprinter and the imprinter print cartridge. You can use this tab to record that the print cartridge has been replaced.
To open the HP Scanner Tools Utility, press the Tools button on the scanner front panel.
For detailed information on using the HP Scanner Tools Utility, see the HP Scanner Tools Utility help.
