    We are upgrading our website
HP LaserJet M1319f Multifunction Printer - Receiving a Fax
This document includes instructions on how to receive a fax automatically or manually.
Receiving a fax
Depending on the situation, set the product answer mode to Automatic or Manual to receive a fax.
Receiving a fax automatically
The default answer mode is Automatic. In this answer mode, the product answers incoming calls after a specified number of rings or upon recognition of special fax tones. (The default Rings to Answer setting is two rings.)
Receiving a fax manually
When you are on the phone, the person you are speaking with can send you a fax while you are still connected. This is referred to as manual faxing. Use the instructions in this section to receive a manual fax.
  1. Make sure the product is turned on and paper is loaded in the input tray.
  2. Press the Setup button.
  3. Use the arrow buttons () to select Fax setup, and then press the OK button.
  4. Use the arrow buttons to select Fax Recv. setup, and then press the OK button.
  5. Press the OK button to select Answer mode.
  6. Use the arrow buttons () to select Manual, and then press the OK button.
  7. When you hear fax tones from a sending fax machine, press the Start Fax button on the control panel.
  8. After the device begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
Country: Flag Serbia
