    Fix HP Printer issue on macOS
HP L2208w 22-inch Widescreen LCD Monitor Product Specifications
Product description
Essential, every day performance Presentation and user comfort features include: · Crisp, clear views of text, graphics, and video from 1000:1 contrast ratio and a bright 300-nit screen* · Power button disable function that prevents users from turning off the monitor · Power LED on/off control to disable the green power light and help minimize distraction · Wide 160-degree viewing angles and a full range of tilt settings to help users find a comfortable viewing position. Smart software HP Display LiteSaver allows pre-scheduled Sleep modes to help protect against image retention and lower power consumption and energy costs. HP Display Assistant enables monitor adjustment, theft deterrence, and color calibration through the connected PC.
Product features
Feature
Part number
GX007AA
Type
22-inch diagonal Wide-Aspect Active Matrix TFT (thin film transistor).
Viewable image area
22 in (55.9 cm) widescreen; diagonally measured (WXGA+)
Viewing angle
Up to 160° horizontal/160° vertical (10:1 minimum contrast ratio)
Brightness (typical)
300 nits
Contrast Ratio (typical)
1000:1
Response Rate
5 ms (on/off)
Frequency
24 to 83 kHz (VGA input); 50 to 76 Hz (VGA input)
Resolutions supported
1440 x 900 @ 60 Hz; 1280 x 1024 @ 60 Hz and 75 Hz; 1024 x 768 @ 60 Hz and 75 Hz; 800 x 600 @ 60 Hz and 75 Hz; 640 x 480 @ 60 Hz and 75 Hz; 720 x 400 @ 70 Hz; 1152 x 870 @ 75 Hz and 832 x 624 @ 75 Hz; 1152 x 900 @ 66 Hz
Input signal
15-pin D-sub (analog VGA)
VGA cable
Detachable 15-pin D-sub mini connector
User Controls
Brightness, contrast, positioning, color temperature (6500k, 9300k, custom), individual color control, serial number, display, clock, clock phase, monitor management, factory reset, zoom.
Built-in power supply
Auto-Sensing, 100 to 240 VAC, 50 +/-3 Hz to 60 +/-3 Hz)
Power consumption
Maximum: 50 watts; Typical: 41 watts; Power saving: 2 watts standby; Off: 1 watt.
Dimensions (h × w × d)
Unpacked w/stand: 16.32 x 20.27 x 7.56 in (41.46 x 51.48 x 19.2 cm) Unpacked w/o stand (head only): 13.59 x 19.72 x 2.36 in (34.52 x 51.48 x 6.0 cm) Packaged: 18.94 x 23.43 x 7.48 in (48.1 x 59.5 x 19 cm)
Head only: 10.36 lbs (4.7 kg); Unpacked: 11.93 lbs (5.41 kg); Packaged: 16.54 lbs (7.51 kg).
Base features
Tilt range: -5° to + 25° vertical
Operating temperature
41° to 104° F (5° to 40° C)
Options
HP LCD Panel Speaker Bar—Optional; powered directly by the connected PC, seamlessly attaches to the monitor's bezel to bring full multimedia support to select HP LCD monitors; features dual speakers with full sound range, external jack for headphones. Part number EE418AA. For more information, refer to the product's Quick Specs.
HP LCD Monitor Quick Release—Optional; easy-to-use, VESA-compliant, flat panel monitor mounting solution that allows quick and secure attachment of an LCD monitor to a variety of stands, brackets, arms or wall mounts. Part number EM870AA. For more information, refer to the product's QuickSpecs.
HP Compaq dc 7800 Series Ultra-slim Desktop Integrated Work Center Stand: Allows mounting of the monitor and an HP Compaq dc7800 Ultra-slim Desktop PC or thin client on a single stand for the convenience of an "all-in-one" form factor. Sold separately, part number GN783AA. For more information, refer to this product's QuickSpecs.
Certification and Compliance
TCO’03, ISO 13406-2 VDT Guidelines Approval, MPR-II Compliant, CISPR Requirements, VCCI Approvals, MIC (Korean) Requirements, CSA, Australian ACA Approval, “GS” Mark, TUV Approvals, CE Marking, FCC Approval, ENERGY STAR Qualified, PC-2001 Certified, Microsoft Windows Certification (Microsoft Windows 98, Microsoft Windows 2000, Microsoft Windows XP, and Windows Vista).
Warranty information
Three years parts, labor, and on-site service. 24-hour, 90-day, toll-free technical support. Replacement options may include second business day on-site service, or next business day direct replacement, at HP's sole discretion.* With direct replacement, HP will ship a replacement display product directly to you. Using the prepaid shipping labels provided, return your failed display to HP in the same packaging as the replacement. Certain restrictions and exclusions apply. For details see your product warranty or contact HP Customer Support.
