HP L2245w 22-inch Widescreen LCD Monitor Product Specifications
Product description
Impressive performance Enjoy crisp, clear, high-resolution onscreen presentation from the 1000:1 contrast ratio, bright 300-nit screen, and 92% color gamut. Additional features include: · Swivel feature: Swivel the monitor panel left to right independent of turning the whole base. Improved cable management: Route cables cleanly down the sides and behind the monitor. Power button disable: Disable the power button to prevent users from turning off the monitor, if desired. Power LED on/off control: Disable the green power light on the front to minimize distractions. OSD menu rotation: Rotate the menu into portrait orientation. Set Refresh: Automatically optimize settings. HP Display Assistant: Set theft deterrence features and adjust the display through software instead of the onscreen display (OSD)
Product features
Feature
Model
GX008AA
Type
22-inch Wide-Aspect Active Matrix TFT (thin film transistor).
Viewable image area
22 inch (55.9 cm) widescreen; diagonally measured (WSXGA+).
Viewing angle
Up to 160° horizontal/160° vertical (10:1 minimum contrast ratio).
Brightness (typical)
300 nits (cd/m2)
Contrast Ratio (typical)
1000:1
Response Rate
5 ms (On/Off)
Native Resolution
1680 x 1050 @ 60 Hz (WSXGA+), 1.76 Million pixels
Input signal
VGA and DVI-D (VGA cables included).
VGA cable
15 pin D-sub VGA.
User Controls
Brightness, contrast, positioning, color temperature (6500k, 9300k, custom), individual color control, serial number, display, clock, clock phase, monitor management, factory reset, zoom.
Self powered USB 2.0 hub
One upstream, two downstream ports (cable included).
Built-in power supply
Yes
Power consumption
60 watts (USB ports fully loaded) typical; < 65 watts maximum; < 2 watts power saving.
Options
HP LCD Speaker Bar - Optional; powered directly by the monitor, seamlessly attaches to the monitor's bezel to bring full multimedia support to select HP LCD monitors; features dual speakers with full sound range, external jack for headphones. Part number EE418AA. For more information, refer to the product's Quick Specs.
HP Quick Release - Optional; easy-to-use, VESA-compliant, LCD monitor mounting solution that allows quick and secure attachment of an LCD monitor to a variety of stands, brackets, arms or wall mounts. Part number EM870AA. For more information, refer to the product's QuickSpecs.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
