HP iPAQ 310 Travel Companion Series - Changing Night Mode
Issue:
If the HP iPAQ 310 Travel Companion Series device is stuck in Night Mode, check to see that the Night Mode setting is not On.
Solution
Complete the following steps to check the Night Mode setting:
  1. Tap Settings.
  2. Tap Visual > Map Settings.
    On bottom right, options for Night Mode are displayed.
  3. Choose from: On, Auto, or Off.
    Choosing Auto changes to Night Mode depending on the region and time.
