HP iPAQ 310 Travel Companion - Saving a Phone Number from Call History to a Contact
Issue:
How is a phone number from call history saved to a contact?
Solution
Complete the following steps:
  1. Tap Settings > Bluetooth > Key Pad.
  2. Tap the Call History icon.
  3. Select the phone number that you want to save to a Contact from the list.
  4. Tap the Move to Contact list icon.
  5. Select the Contact under which to save the number.
    You are prompted to select a field in which to store the new number.
  6. Tap OK.
  7. Select the field where you want to put the number.
  8. Tap the checkmark icon.
    The number is now saved under the selected Contact.
