Figure : HP LaserJet M1319f multifunction printer
The specifications for the product are as follows.
HP multifunction printer model
Model
Part Number
CB536A
System requirements
Windows
Feature
Minimum system requirements
Microsoft Windows XP (32-bit and 64-bit)
Processor
Pentium 233 MHz processor
RAM
128 MB
Free disk space
150 MB
Browser
Internet Explorer 6.0
Microsoft Windows Vista (32-bit and 64-bit)
Processor
1 GHz or faster 32-bit (x86) or 64-bit (x64) processor
RAM
1 GB (32-bit) or 2 GB (64-bit)
Free disk space
920 MB
Browser
Internet Explorer 7.0
Microsoft Windows 7 (32-bit and 64-bit)
Processor
RAM
Free disk space
920 MB
Browser
Internet Explorer 8.0
Macintosh
Mac OS X v10.3.9 and Higher
Processor: PPC and Intel Core Processor Macs
RAM: 32 MB
Memory: 4-megabyte (MB) flash fax-storage memory
Connectivity
Connectivity
Open USB port
RJ-11 fax port
RJ-11 line-out telephone port
Physical dimensions
Dimension
Measure
Height
459 mm (18.1 inches)
Depth
443 mm (17.3 inches)
Width
429 mm (16.9 inches)
10 kg (22 lb)
Print Cartridges
Color
Print cartridge number
Black
Q2612A
Paper-handling specifications
Paper tray capacities
The product has the following tray priority for feeding paper.
Priority input tray
Tray 1
The following table lists the capacities of the priority input tray and tray 1 for different paper types.
Paper type
Paper specifications
Priority input tray
Tray 1
Plain
Color
Preprinted
Prepunched
Recycled
75 g/m2 (20 lb) to 104 g/m2 (27 lb)
Up to 10 sheets
Up to 250 sheets
Light
60 g/m2 (16 lb) to 75 g/m2 (20 lb)
Up to 10 sheets
Up to 260 sheets
Envelopes
Less than 90 g/m2 (24 lb)
1 envelope
Up to 10 envelopes
Labels
Standard
1 sheet
Not supported
Bond
1 sheet
Up to 250 sheets
Rough
1 sheet
Up to 200 sheets
Transparencies
4 mm (0.1 inches) Monochrome
Overhead
1 sheet
Up to 200 sheets
Heavy
110 g/m2 (29 lb) to 125 g/m2
(33 lb)
Up to 10 sheets
Not supported
Letterhead
lb)
Up to 10 sheets
Up to 250 sheets
note:The maximum stack height for tray 1 is 25 mm (1 inch).
Paper sizes
Following paper sizes can be used with the product.
Plain paper
Type
Size
Letter
216 x 279 mm (8.5 x 11 inches)
Legal
216 x 356 mm (8.5 x 14 inches)
A4
210 x 297 mm (8.27 x 11.69 inches)
Executive
184 x 267 mm (7.24 x 10.51 inches)
A5
148 x 210 mm (5.83 x 8.27 inches)
A6
105 x 148 mm (4.13 x 5.83 inches)
B5 (JIS)
182 x 257 mm (7.17 x 10.12 inches)
16k
197 x 273 mm (7.75 x 10.75 inches)
16k
195 x 270 mm (7.7 x 10.6 inches)
16k
184 x 260 mm (7.25 x 10.25 inches)
Custom
216 x 330 mm (8.5 x 13 inches)
Custom
107 x 152 mm (4 x 6 inches)
Custom
127 x 203 mm (5 x 8 inches)
Custom
100 x 150 mm (3.9 x 5.9 inches)
Envelopes and postcards
Type
Size
Envelope #10
105 x 241 mm (4.13 x 9.49 inches)
Envelope DL
110 x 220 mm (4.33 x 8.66 inches)
Envelope C5
162 x 229 mm (6.93 x 9.84 inches)
Envelope B5
176 x 250 mm (6.7 x 9.8 inches)
Envelope Monarch
98 x 191 mm (3.9 x 7.5 inches)
Postcard
100 x 148 mm (3.94 x 5.83 inches)
Double postcard
148 x 200 mm (5.83 x 7.87 inches)
Printing specifications
Print speed: Up to 19 ppm for Letter, and up to 18 ppm for A4
Resolution: 600 dots per inch (dpi) and FastRes 1200 dpi
Duty cycle: 8,000 pages per month
Supports manual two-sided (duplex) printing
Copying specifications
Copies at 300 dots per inch (dpi)
Supports manual two-sided (duplex) copying
Scanning specifications
Automatic Document Feeder (ADF)
The product supports a 30-page automatic document feeder.
Other specifications
Resolution: Up to 600 by 600 dpi, 24 bit (up to 19,200 dpi enhanced)
Interfaces: Walk-up scanning via front control panel with Copy or Fax buttons, remote scanning via Scan To software, HP Director (Macintosh), and TWAIN- or WIA-compliant software
Supported file types: JPEG, TIF, BMP, GIF, PDF, and PNG
Methods: Scanning from HP LaserJet Scan (Windows), HP Director (Macintosh), and TWAIN-compliant or Windows Imaging Application (WIA)-compliant software
Faxing specifications
V34 fax modem: 3 seconds per page
Fax speed: Up to 33.6 kbps
Resolution (Best mode): 300 by 300 dpi
Speed-dial: Up to 120 numbers
Supports an integrated telephone handset, automatic redial, digital storage of up to 500 fax pages, junk fax blocking, fax forwarding, delayed sending of faxes, and eight cover page templates
Power specifications
Required input voltage:
110 to 127 V (±10 percent), 60 Hz (±2 Hz)
220 to 240 V (±10 percent), 50 Hz (±2 Hz)
Power consumption:
Active: 365 watts
Sleep: 8 watts
Ready: 8 watts
Off: 0.1 watts
Environmental specifications
Recommended operating conditions
Temperature: 15 to 32.5 degrees C (59 to 90.5 degrees F)
Relative humidity: 10 to 80 percent
Storage conditions
Temperature: -20 to 40 degrees C (-4 to 104 degrees F)
Relative humidity: 0 to 95 percent
Energy Star
Energy usage drops significantly while in ENERGY STAR mode, which saves natural resources, and saves money without affecting the high performance of this product. This product qualifies for ENERGY STAR, which is a voluntary program established to encourage the development of energy-efficient office products.
ENERGY STAR is a U.S. registered mark of the U.S. EPA. As an ENERGY STAR partner, Hewlett-Packard Company has determined that this product meets the ENERGY STAR guidelines for energy efficiency. For more information, go to www.energystar.gov.
Material safety data sheets
Click here to get the Material safety data sheets (MSDS).
Ozone production
This product generates no appreciable ozone gas (O3).
Paper and plastic use
This product is suited for the use of recycled paper according to DIN 19309. Plastic parts over 25 grams are marked according to international standards that enhance the ability to identify plastics for recycling purposes at the end of the product's life.
Recycling program
HP offers an increasing number of product return and recycling programs in many countries/regions and partners with some of the largest electronic recycling centers throughout the world. HP conserves resources by reselling some of its most popular products. More information on www.hp.com/go/recycle is available from the HP Web site.
