- ${title}
- ${title}
- ${title}
- ${title}
HP Photosmart C4400 and C4424 All-in-One Printer series - Setting up the All-in-One (Hardware)
Unpack the All-in-One
Check the contents of the box
Connect the power cord and adapter
Turn on power
Select the language/region
Install the cartridges
Load plain paper
Align the cartridges
Follow these steps in order.
Lower both the paper tray and the cartridge door.Figure : Lower the paper tray
Remove all packing material from the product and remove any sticker from the control panel display screen.Figure : Remove the packaging material
Close the cartridge door.
Step three: Connect the power cord and adapter
Connect the power adapter to the back of the product.
Connect the power cord to the power adapter.
Connect the other end of the power cord to an alternating current (AC) power outlet.Figure : Plug in the power cord
Step four: Turn on power
Press the Power button (
) to turn on the
product.
Figure : Turn on the All-in-One
note:Pay attention to the helpful messages on the control panel display screen during the setup process.
Step five: Select the language/region
Follow the instructions on the product control panel display to set the default language and country/region.
Press the colored buttons to the left of the display to select the up arrow (
) or down arrow (
) icons on the display until your language is selected.
Press OK to confirm.
) or down arrow (
) icons on the display until your country/region is selected.
Step six: Install the cartridges
Make sure the product is turned on and then open the cartridge door.The carriage moves to the right side of the printer. Wait until the carriage is idle and silent.Figure : Open the cartridge door
Remove the new cartridge from its packaging and carefully remove the plastic tape using the pink pull tab. Hold the cartridge so that the copper strip is on the bottom and facing toward the product.Figure : Remove the tape
Do not touch the copper-colored contacts or ink nozzles. Also, do not re-tape the cartridges. Doing so can result in clogs, ink failure, and bad electrical connections. -
Hold the cartridge with the HP logo on top, and insert the new cartridge into the empty cartridge slot.
If installing the tri-color cartridge, slide it into the left slot.
If installing a black, photo, or gray photo cartridge, slide it into the right slot.
Figure : Insert the cartridges -
Push the cartridge firmly into the slot until it snaps into place.
Press OK to confirm the cartridge installation.
Step seven: Load plain paper
Pull out the tray extender.Figure : Pull out the tray extender
Slide the paper-width guide to its outermost position.
Insert the stack of paper into the input tray with the short edge forward and the print side down. Slide the stack of paper forward until it stops.
Make sure all the paper in the stack is the same size and type and free of rips, dust, wrinkles, and curled or bent edges.Figure : Load papercaution:
Make sure that the product is idle and silent when paper is loaded into the input tray. If the product is servicing the cartridges or otherwise engaged in a task, the paper stop inside the device might not be in place. The paper could be pushed too far forward, causing the product to eject blank pages. -
Slide the paper-width guide inward until it stops at the edge of the paper.Do not overload the input tray; make sure the stack of paper fits within the input tray and is no higher than the top of the paper-width guide.
Press OK.
Step eight: Align the cartridges
Follow the instructions on the control panel display screen to print an alignment page.The product prints an alignment page.Figure : Alignment page
Place the alignment page print-side down on the right front corner of the glass.Figure : Position the alignment page
Press OK.When the On button stops flashing, the alignment is complete. Remove the page and recycle or discard it.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
