HP iPAQ 600 Business Navigator Series - Setting up Different E-mail Accounts
To send and receive e-mail messages for an e-mail account, you need to connect to the Internet or your corporate network, depending on the account.
You can send and receive:
  • Outlook e-mail
  • Internet e-mail through an Internet Service Provider (ISP)
E-mail in the Outlook e-mail account is sent and received through synchronization with a computer using a synchronization software or through wireless synchronization directly with an Exchange Server.
Internet e-mail is sent and received by connecting to a Post Office Protocol 3 (POP3) or Internet Message Access Protocol 4 (IMAP4) e-mail server.
Setting up e-mail using exchange server
You can set up your e-mail using exchange server.
  1. Tap Messaging > New E-mail Account.
    Figure : Setting up new e-mail account
  2. Type your e-mail address in the E-mail address box.
  3. Clear the Try to get e-mail settings automatically from the Internet check box, to manually configure your e-mail.
  4. Tap Next.
  5. Select the Exchange server option from the Your e-mail provider list and tap Next.
    Figure : Selecting the exchange server option
  6. Tap Next to synchronize outlook with your organization's Exchange e-mail server.
  7. In the Server address box, type your Outlook Web Access server address and tap Next.
    Figure : Typing the server address
    Select This server requires an encrypted (SSL) connection check box to ensure you always send e-mail from this account using an SSL connection.
  8. Type the User name, Password, and Domain on the Edit Server Settings screen.
  9. Select the check box for the items you want to synchronize, and tap Finish.
Creating a new POP3 or IMAP4 account
You must set up an e-mail account that you have with an ISP or an account that you access using a VPN server connection (typically a work account) before you can send and receive e-mail.
These steps will help you to create a new POP3 or IMAP4 account.
  4. Tap Next.
  5. Type your name and required account name on the E-mail Setup screen and tap Next.
  6. Type the incoming mail server name and select POP3 or IMAP4 from the Account type list.
    Figure : Selecting the account type
  7. Tap Next.
  8. Specify the information required over the next few screens, and then tap Finish.
Deleting an account
Follow the steps to delete an account.
  1. Tap Messaging > Menu > Options.
  2. Tap and hold the account name, and tap Delete.
You cannot delete your text message, Outlook E-mail, Windows Live, and MMS accounts.
