HP iPAQ 600 Business Navigator Series - Product Specifications
System specifications
System Feature
Processor
Marvell PXA270, 520 MHz
Operating System
Microsoft® Windows Mobile 6 Professional
Memory
128 MB SDRAM/256 MB Flash ROM
External Power
Power adapter: input 100–240 Vac, 200 mA, 50 to 60 Hz and output +5 Vdc, 1 A
USB charger: 5 Vdc, 100/500 mA
2.8” 240x320 TFT LCD with touch screen
SD Slot
Supports MicroSD memory
Headphone Jack
Microphone input jack, combined with headphone jack
Antenna
Internal Wi-Fi and Bluetooth antennas
This component will not be visible externally.
Battery
1590 mAh Li-polymer removable/rechargeable battery
Bluetooth
10 m range (approximately 33 ft) – High-speed, low-power, short-range wireless communication with other Bluetooth devices
Wi-Fi
IEEE 802.11b/g
Camera
  • 3 Megapixels
  • Auto-focus (10 cm to infinity)
  • 4x Digital Zoom
  • Video recording with audio (max. QVGA)
The camera is not available on all models.
Physical specifications
US
Metric
Length
4.61 inches
117 mm
Width
2.37 inches
60.3 mm
Depth
0.69 inches
17.5 mm
  • With battery: 5.1 oz
  • Without battery: 4.021 oz
  • With battery: 145 g
  • Without battery: 114 g
Operating environment
US
Metric
Temperature
Operating
14° to 131° F
–10° to 55° C
Non-operating
4° to 140° F
–20° to 60° C
Relative Humidity
Operating
85 % RH
85 % RH
Non-operating
90 % RH
90 % RH
