Document ID: c01362512
Version: 1
HP Compaq 6910p Notebook PC System BIOS Update Version F.13
Release date : 06-Feb-2008
Last updated : 06-Mar-2008
DETAILS OF CHANGE
This product change notification affects systems that were using system BIOS version F.10 and have upgraded to system BIOS version F.12.
  • Added option in F10 Setup where modem can be enabled or disabled.
  • Added support for the following new Intel Penryn processors:
    • X9000 2.8 GHz
    • T9500 2.6 GHz
    • T9300 2.5 GHz
    • T8300 2.4 GHz
    • T8100 2.1 GHz
  • Added a BIOS boot block update that eliminates a potential security vulnerability.
  • For F.12 BIOS users using Centrino Pro with Discrete graphics systems (UMA graphics systems are not affected): A firmware module build error was introduced with the release of the F.12 BIOS. The F.13 BIOS release corrects this issue.
Restore F10 Setup to the default settings and reboot the system after upgrading the system BIOS.
REASON FOR CHANGE
To implement changes under "Details of Change."
IMPACT OF CHANGE
Previous versions of the system BIOS cannot be reinstalled after system BIOS version F.13 has been installed.
F.12 BIOS users with Centrino Pro systems (with Discrete graphics) should install the F.13 BIOS to avoid loss of any AMT functionality due to a firmware module build error that was introduced with the F.12 BIOS.
Components affected:
DATE OF CHANGE
Effective date : 28-Feb-2008
Hardware platforms affected : HP Compaq 6910p Notebook PC
