    Fix Windows 10 Update Issues
HP t5520 Thin Client - How to Install Elo Touch Screen Drivers
Issue:
This document explains how to install drivers for Elo Touch screen monitors on the HP t5520 Thin Client.
Solution
Complete the following steps:
  1. Download Altiris CE (EloTouch Add-on) from the software and driver downloads page for the HP t5520 Thin Client on the HP website. Click here to go to the HP website (http://www.hp.com).
  2. Save sofpaq 30530.exe.
  3. Execute the sofpaq and click unpack the files used to perform the installation to the location specified below.
  4. Click change.
  5. Select the desktop or any location of choice.
  6. Open the folder CE_Cabs.
  7. Transfer the EloTouch.CAB zip file to the thin client using a USB storage device.
  8. Drivers for Elo Touch screen monitors can also be downloaded from the Elo TouchSystems Corporate website. Click here to go to the Elo TouchSystems Corporate website (http://www.elotouch.com).
