HP Handheld sp400 Series All-in-One Scanner Printer - System Requirements
  • All-in-One device and accessories
  • Wireless network and server application
  • Computer with the following installed:
    • Windows XP and Service Pack 2
    • Microsoft .NET Framework 2.0 or later
    • HP sp400 Series Configuration Software
    • HP sp400 Series Template Design Software
  • USB-compliant cable that does not exceed three meters (10 feet) in length, with a type B 5-pin plug at one end to connect to the All-in-One's port
If you are connected to the internet when you install the software and you do not have .NET Framework installed on your computer, .NET Framework will automatically be downloaded and installed.
Country: Flag Serbia
