    Fix HP Printer issue on macOS
HP iPAQ 300 Travel Companion Series - Product Specifications
System specifications
System Feature
Processor
Titan 600 MHz ARM11 Dual-Core Processor
Operating System
Microsoft® Windows Mobile® CE
Memory
Up to 2.0 GB flash ROM for persistent storage, depending on model
128 MB SDRAM for running applications
External Power
AC Input: 100~240 Vac, 50/60 Hz, AC Input current: 0.2 A ac max Output Voltage: 5Vdc (typical)
4.3" WVGA 800x480 TFT with touch screen, antiglare, landscape oriented, 16bit RGB depth
SD Slot
Supports SD memory
Antenna
Internal Bluetooth antenna
Audio
Integrated microphone, speaker, and one 3.5–mm stereo headset jack, 5–band equalizer and 3D sound adjustment
Battery
1,700 mAh Li-ion removable/rechargeable battery
Bluetooth
Bluetooth 2.0 with Enhanced Data Rate, typical 10 meter range (approximately 33 feet)–High-speed, low-power, shortrange wireless communication with other Bluetooth devices
LED Indicators:
Charge and Notification LED
  • Solid Amber – Battery charging
  • Solid Green – Battery fully charged
Wireless LED
  • Blue indicates:
    • Bluetooth on
  • LED off indicates Bluetooth is off
GPS Receiver
SiRF embedded GPS receiver with InstantFix(TM) time to first fix acceleration
GPS Antenna
Internal patch antenna
Physical specifications
US
Metric
Width
4.3 in
110.2 mm
Height
3.4 in
86.8 mm
Depth
0.7 in
18.2 mm
6.6 oz
187 g
Operating environment
US
Metric
Temperature
Operating
32° to 104° F
0° to 40° C
Nonoperating
-9.6° to 140° F
-20° to 60° C
Relative Humidity
Operating
up to 85 %
up to 85 %
Nonoperating
up to 85 %
up to 85 %
Maximum Altitude
Operating
0 to 15,000 ft
0 to 4572 m
Nonoperating
0 to 40,000 ft
0 to 4572 m
