HP iPAQ 300 Travel Companion Series - Power Saving Tips
There are certain settings you can change on your HP iPAQ 300 Travel Companion series device to make your battery last as long as possible between charges.
Set Idle Timeout
You can set the behavior of the display when the screen has been untouched for a while.
  1. Tap Settings > System.
  2. Adjust idle time out to the desired interval.
Adjust backlight settings
You can set the backlight level separately for both daylight and night modes, thus enhancing the effect of the night color scheme.
  1. Tap Navigation > Settings > Visual > Backlight Settings.
  2. Adjust the back light settings for day and night.
Enable Smart Power Save
When running on battery, Smart Powersave lights up the screen only when you press a button, tap on the screen, or if an event occurs on the screen. After a few seconds, the light level decreases, and after another few seconds, the backlight turns off.
  2. Switch to Smart Power save.
