HP Designjet T1100 and T1120 MFP Series Products - Create custom input and output size presets
The following instructions apply for creating either a custom input size - paper size preset or a custom output size - paper size preset.
  1. Press the Copy tab or Scan tab. Scan tabCopy tab
  2. Press the Input Size or Output Size option and then the Tool button . When in the Scan tab, the Output size dialog is reached through the Resize -> Size option.
  3. In the Size Setup dialog, press the New button.Output size setup
  4. Enter a name for your new size. The name could describe a certain group of copies or the size itself i.e., "23x50".
  5. Press the Width and Length buttons and set the values. The Auto options can also be used.
  6. Press the Save button and then OK to confirm.
Your new size preset will join the standard sizes in the size presets lists.
