Document ID: c01206534
Version: 1
Enable/Disable splash screen to include name, asset tag, etc.
Release date : 25-Sep-2000
Last updated : 25-Sep-2000
DESCRIPTION
How to enable/disable the user definable splash screen during post.
sourceInformation
SCOPE
Armada E500, Armada E700, Armada M300, Armada M700, Armada V300 with user definable Splash Screen during post.
RESOLUTION
Instructions on how to enable/disable the user definable splash screen (information displayed during post, e.g. Compaq Logo Screen) during post is not clear. There is no need to replace the system board or clear CMOS to change or disable the user definable splash screen.
Use the following procedure to display (enable) and customize the user definable splash screen during post.
  1. During boot, enter the power-on password if required, press F10 when you see the cursor on the upper right during the Compaq logo screen.
  2. From the Security menu select System ID's.
  3. From the System ID section edit/add the information needing to be displayed during the Compaq logo screen during Boot in the NOTEBOOK OWNERSHIP TAG field.
  4. Press F10 to accept the changes.
  5. From the FILE MENU, select save changes and exit.
  6. Press F10 to confirm the changes.
To remove (disable) the user definable splash screen during post, follow the above procedure, but delete any text in the NOTEBOOK OWNERSHOP TAG field.
Downloadable Solutions
Downloadable File
Location
None
REVISION HISTORY : Release Date: 2000-09-25 Document ID: PS000410_CW01
Hardware platforms affected : Compaq Armada E700 Notebook PC series, Compaq Armada V300 Notebook PC series, Compaq Armada e500 Notebook PC, Compaq Armada m300 Notebook PC series, Compaq Armada m700 Notebook PC
Support Communication Cross Reference ID : IA01206534
Country: Flag Serbia
