Printer Specifications for HP Officejet K7100, K7103, and K7108 Color Printer Series
Figure : HP Officejet K7100 Printer Series
Image of the HP Officejet K7100 printer
Printer models
Printer model
Part number
CB041A
HP Officejet K7103 Printer
CB041C
HP Officejet K7108 Printer
CB041D
System requirements
Windows
Component
Minimum system requirements
Operating System
Windows 2000, Windows XP, Windows Vista, Windows 7
Processor
Windows 2000 and XP: Minimum: Intel Pentium II 233 MHz or greater (Pentium 4 or greater recommended)
Windows Vista and Windows 7: 800 MHz 32-bit (x86) or 64-bit (x64) processor (1 GHz or higher recommended)
RAM
Windows 2000 and Windows XP: 128 MB RAM (256 MB RAM recommended)
Windows Vista and Windows 7: 512 MB RAM (1 GB or higher recommended)
Free disk space
Windows 2000 and Windows XP: 795 MB
Windows Vista and Windows 7: 850 MB
CD-ROM drive
4x (CD-RW recommended)
Browser
Microsoft Internet Explorer 6 or higher
Connectivity
Available USB port (cable not included)
Macintosh
Component
Minimum
Recommended
Mac OS X (10.3.8 and higher, 10.4.6 and higher): 400 MHz Power PC
Processor
G3 (v10.3.8 and higher, 10.4.6 and higher) or 1.83 GHz Intel Core Duo (10.4.6 and higher)
G4 (v10.3.8 and higher, 10.4.6 and higher) or 1.83 GHz Intel Core Duo (10.4.6 and higher)
RAM
256 MB memory
256 MB memory
Free disk space
200 MB free hard disk space
500 MB free hard disk space
Internet Explorer version
Microsoft Internet Explorer 6.0
Microsoft Internet Explorer 6.0 or later
Environment specifications
Operating temperature:
5° to 40°C (41° to 104°F)
Recommended operating conditions:
15° to 30°C (59° to 95°F)
Storage temperature:
–40° to 60°C (–40° to 140°F)
Relative humidity:
20 to 80% RH non-condensing
Noise levels per ISO 9296:
Sound power LwAD: 6.1 B(A)
Physical dimensions
Height
186.3 mm (7.33 inches)
Width
574.5 mm (22.62 inches)
Depth
409.5 mm (16.12 inches)
With input tray fully extended: 631.0 mm (24.84 inches)
11 kg (24.25 lb)
Print resolution
Color resolution
Maximum of 4800 x 1200 dpi*
*Up to 4800 x 1200 optimized dpi for color printing and 1200 input dpi. This setting might temporarily use a large amount of hard disk space (400 MB or more) and will print more slowly. A photo cartridge, if present, further enhances the print quality.
Internal memory
16 MB of built-in RAM
Duty cycle
Up to 5,000 pages per month
Paper specifications
Paper types supported
Supported paper types: Plain, inkjet, photo, glossy, banner
Standard U.S
Media
Margins
Letter
8.5 x 11 inches
Legal
8.5 x 14 inches
Tabloid
11 x 17 inches
Super B
13 x 9 inches
Executive
7.25 x 10.5 inches
Statement
5.5 x 8.5 inches
4 x 6 inches
Standard International:
Media
Margins
A6
105 x 148.5 mm
A5
148.5 x 210 mm
A4
210 x 297 mm
A3
297 x 420 mm
A3+
330 x 482 mm
JIS-B4
257 x 364 mm
JIS-B5
182 x 257 mm
Transparencies
Size
US Letter
8.5 x 11 inches
A4
210 x 297 mm
Envelopes:
Media
Margins
US No. 10
4.12 x 9.5 inches
US A2 Invitation
4.37 x 5.57 inches
US Monarch
3.87 x 7.5 inches
European DL
110 x 220 mm
C5
162 x 229 mm
C6
114 x 162 mm
Index Cards: US Index card (4 x 6 inches), US Index card (5 x 8 inches), A6 card (105 x 148.5 mm)
Labels: US Labels (8.5 x 11 inches), A4 Labels (210 x 297 mm)
Custom size: 89.9 x 146.05 mm (3.54 x 5.75 inches) to 330.2 x 1,270 mm (13 x 50 inches)
Paper tray capacity
Tray
Capacity
Input tray:
Up to 19 mm (0.75 inches) or up to 150 sheets plain paper
Up to 15 envelopes
Up to 60 cards
Up to 30 transparencies or labels
Photo media
Output tray:
Up to 75 sheets
Rear manual feed slot
Single sheet
Thick media (up to 0.3 mm)
Envelopes
Cards
Transparencies
Labels
Optional automatic two-sided printing accessory (duplex unit)
13 x 19 inches
11 x 17 inches
Legal
Letter
Executive
A3+
A3
A4
B5 (JIS) or larger than 13 x 19 inches/ A3+
Power specifications
Power consumption
60 watts maximum
Power supply
Built-in Universal Power Supply
Power requirements
Input 100-240V AC, 1300 mA 50/60Hz
Output 32V DC, 1500mA
I/O Interface
IEEE 1284-Centronics parallel compatible; Universal Serial Bus (USB)
Energy star
This product is designed to reduce power consumption and save natural resources without compromising product performance. It has been designed to reduce total energy consumption both during operation and when the device is not active. This product qualifies for ENERGY STAR®, which is a voluntary program established to encourage the development of energy-efficient office products.
ENERGY STAR is a U.S. registered service mark of the U.S. EPA. As an ENERGY STAR partner, HP has determined that this product meets ENERGY STAR guidelines for energy efficiency.
For more information, go to the Energy Star website (in English).
Material safety data sheets
Click here to get the Material safety data sheets (MSDS).
Recycling program
HP offers an increasing number of product return and recycling programs in many countries/regions and partners with some of the largest electronic recycling centers throughout the world. HP conserves resources by reselling some of its most popular products. More information on www.hp.com/go/recycle is available from the HP Web site.
Paper and Plastic use
This product is suited for the use of recycled paper according to the DIN 19309 and EN 12281:2002.Plastic parts over 25 grams are marked according to the international standards that enhance the ability to identify plastics for recycling purposes at the end of product life.
Ozone production
This product generates no appreciable ozone gas (O3).
