    Fix Windows 10 Update Issues
HP Printers - Using the Printer Embedded Web Server (EWS)
This document is for HP network-capable printers and Wi-Fi Direct printers.
The HP Embedded Web Server (EWS) is a printer homepage accessed through a web browser for managing settings, getting updates, and performing maintenance tasks.
Example of the EWS home page on a computer
There are several ways to open the printer homepage:
  • For printers connected to a local network: Obtain the printer IP address, the unique identification number assigned to the printer on the network, and enter it into a web browser address bar.
  • Use the HP Smart app: Available through the printer settings in the HP Smart app on your computer or mobile device.
  • Connect to the printer with Wi-Fi Direct: Set up this direct wireless connection to the printer, and then enter the IP address 192.168.223.1 into a web browser address bar.
Select your preferred method for detailed steps to open the printer homepage.
Frequently asked questions
Learn how to use or change printer settings from the printer homepage and resolve connection issues.
