    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP Officejet J5508 and J5520 All-in-Ones - Installing Print Cartridges
This document provides information about installing and aligning print cartridges in the All-in-One.
Install the print cartridges
Use the following instructions to install and align print cartridges.
Step one: Install the print cartridge
Use the following steps to install the cartridges.
Leave the product turned on to install the cartridges.
  1. Open the cartridge door.
    The carriage moves to the far right side of the product.
    Figure : Open the cartridge door
  2. Remove the new cartridge from its packaging and, being careful to touch onlythe black plastic, gently remove the protective plastic tape.
      Figure : Remove protective tape
    1. Copper-colored contacts
    2. Plastic tape with pink pull tab (must be removed before installing)
    3. Ink nozzles under tape
    Do not touch the cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections.Do not remove the copper strips. They are required electrical contacts.
    Figure : Do not touch the ink nozzles or copper contacts.
  3. Slide each new cartridge forward into the empty slot. Gently push on theupper part of the cartridge forward until it clicks into the socket.
    • Insert the tri-color print cartridge into the left slot.
    • Insert the black print cartridge into the right slot.
      Figure : Insert cartridges
  4. Close the cartridge door.
    Figure : Close the cartridge door
Step two: Align the print cartridge
The product prompts you to align cartridges every time you install a cartridge. You can also align the cartridges at any time from the control panel, or by using the software you install with the product. Aligning the cartridges ensures high quality output.
  1. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
  2. Press OK. The product prints an alignment page.
  3. Place the alignment page print-side down on the scanner glass.
  4. Press OK to scan the alignment page. When the scan finishes, the alignment is complete.
If you have colored paper loaded in the input tray when you align the cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
