    Fix HP Printer issue on macOS
HP Designjet T610 Printer Series - AutoCAD 2000 memory allocation error
After installing the printer driver, when you try to print for the first time from AutoCAD 2000, you may see a message saying Memory allocation error, after which your image is not printed.
This is due to a problem in AutoCAD 2000, and it can be fixed by downloading the Plotting Update Patch (plotupdate.exe) from the Autodesk Web site, http://www.autodesk.com/.
This patch is also worth trying if you have any other strange problems when printing from AutoCAD 2000.
